Need help
/ Need help #1
hb1
Lanse MI
Kubota 3710
I know little about hydraulics. I have a Kubota 37.10. I took the bucket off recently and when attaching the snow blower I have no power to the blower. The bucket worked fine but the blower has nothing. Can anyone point be in the right direction?
/ Need help #2
Did you use the curl spool for the hyd?
If you plugged your hyd snow blower into the regen side of the spool, you will not have any flow. You could go to the far right and lock the lever for continuous flow.
You could use the curl up as the supply for the hyd motor and bungee the lever open.
2014 Toro Z-Master 6000 Series 60in Zero Turn Commercial Mower (A59228)
2014 Toro Z-Master...
2012 MACK Tender Truck w/ADAMS Rear Discharge Bed Auger (A61307)
2012 MACK Tender...
INGERSOLL RAND G25 GENERATOR (A58216)
INGERSOLL RAND G25...
TANK MANIFOLD (A58216)
Mini Metal Goat Statue (A55853)
Mini Metal Goat...
2015 Freightliner M2 106 AWD Altec DM478BTR Insulated Digger Derrick Truck (A60460)
2015 Freightliner...
