Hey Al, tell Peg I said hello!
Really, does that model have an electric clutch?? If it does, it sounds like your clutch is stuck, ie not disengaging. If that is the case, you need to determine if the clutch itself has gone bad, or if for some reason it is getting 12Vdc when it shouldn't be (ie, a relay stuck in the energized position maybe). Good luck!
