need help.
   / need help. #1
trailwart
i have an older simplicity 4211H with a briggs 11hp i/c. starts up and runs full power great, but it seems i cant get any throttle response fdrom the lever once its running. im not missing anything according to the parts diagram. is there an adjusment? is it the governer? im lost on this, seems like its rpms are running high.
   / need help. #2
I am not sure what exactly you are saying.Older 11HP BS like to "seek" govenor. BS did make a different spring for the govenor to help with his. Adjust your low and high carb settings. Make sure all linkages are adjusted correctly and not bent way out of shape.
   / need help. #3
Sounds like a governor problem. Weak spring maybe.
This could also be from an air leak in the carb.
Do like Dave suggested and check the settings on your low and high rpm mix screws. You might also check these needle valves for wear. If someone tightened your low rpm mix screw in too tight during a rough tune-up and grooved it, it could be letting too much fuel in now.
2015 DODGE RAM...
2018 FORREST RIVER CRUISE LITE CAMPER (A52472)
2018 FORREST RIVER...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Altec AT41M Boom (A55218)
2016 RAM 5500...
2013 MACK CXU613 (A53843)
2013 MACK CXU613...
MISC WRENCHES (A53843)
1999 CASE 721C WHEEL LOADER (A53843)
1999 CASE 721C...
