Need help zero turn hydro fluid refill
   / Need help zero turn hydro fluid refill #1
pa28pilot
Cub cadet Z-force fab 48
Changed the filters on both hydrostatic units today. Operators manual says to refill through the overflow tank but the fluid just sits in the tank. Seems to be an air lock tank doesn't drain. Is there a vent screw on the transmission that needs to be removed? I am really stuck. Help!!
   / Need help zero turn hydro fluid refill #2
I assume this is in regards to Hydrogear EZT drives?
Per the service manual you need to take the fitting out of the top "fill port" to fill the units.
Joel
Danuser 3 pt Post Hole Digger (A50515)
Danuser 3 pt Post...
UNUSED AGT QUICK ATTACH AUGER SET (A51244)
UNUSED AGT QUICK...
2012 RAM 5500 (A52472)
UNUSED KIVEL SKID STEER QUICK ATTACH PALLET FORKS (A51244)
UNUSED KIVEL SKID...
UNUSED AGT MH12RX EXCAVATOR (A51243)
UNUSED AGT MH12RX...
Land Honor Quick Attach Accumulator Grapple (A50514)
Land Honor Quick...
