Need help with Yanmar engine 3TNE78A-EJTS injection pump part #
   / Need help with Yanmar engine 3TNE78A-EJTS injection pump part # #1
stingray1
Veteran Member
East Tennessee
John Deere 4200 w/backhoe, Ford 3000,Case 580 backhoe
My old injector part #719923-51470 I found a deal on a #729223-51480 is this the same,will it fit on my 3TNE78A-EJTS engine ( 2000 JD 4200) ? Any help or advice would be greatly appreciated. Thanks
   / Need help with Yanmar engine 3TNE78A-EJTS injection pump part # #2
My list of Yanmar Tractor Engs. are from 1975-1992 in the FX Ser. and 3TN84 is the closest I come.
   / Need help with Yanmar engine 3TNE78A-EJTS injection pump part # #3
Ask at a diesel injection rebuild shop
   / Need help with Yanmar engine 3TNE78A-EJTS injection pump part # #4
Sometimes the only difference in Yanmar injection pumps with different part numbers is the little riveted badge that has the engine model number stamped on it. Everything else is the exact same. That being said I have not found anything indicating that the two pumps you listed would interchange.
. Thanks for taking the time to check this out for me.
Looking at the pics. And comparing it to the one on my tractor they look the same,it is new comes with lift pump and shut off sol.for around $200. My old one has 750 hrs.it works good but is leaking fuel into the crankcase.I may pull mine and have it fixed.
Anyone else know about these?
Bump to the top
   / Need help with Yanmar engine 3TNE78A-EJTS injection pump part # #8
Did you try to cross reference the two numbers on the Deere parts site? Are the numbers below Yanmar numbers? Do you know the JD numbers?
719923-51470 and 729223-51480
. I haven't cross referenced on the Deere parts site.
Numbers are Yanmar from the tag on the pumps I'll look up my JD # for my pump tomorrow in my manuel ,as for the 51480# I have no way of knowing. Any help is greatly appreciated. Thanks
   / Need help with Yanmar engine 3TNE78A-EJTS injection pump part # #10
That is a high dollar pump. Error
JOHN DEERE LOT NUMBER 72 (A53084)
JOHN DEERE LOT...
48" Pallet Forks  (A52384)
48" Pallet Forks...
A1 MIST SPRAYERS RESOURCES, IN TERMINATOR 60 R LOT NUMBER 42 (A53084)
A1 MIST SPRAYERS...
New/Unused Fuel Pump with 50ft of Hose (A51573)
New/Unused Fuel...
2020 JOHN DEERE 7R210 LOT NUMBER 48 (A53084)
2020 JOHN DEERE...
2013 Dodge Charger Passenger Car, VIN # 2C3CDXAT6DH646717 (A51572)
2013 Dodge Charger...
