Mowing Need help with rotary cutter choice
   / Need help with rotary cutter choice #1
Deb3
Knoxville, TN
Kubota M5040
I own a 4WD Kubota M5040 which has 46 PTO HP and max lifting of 1200 lbs. I am purchasing a Bush Hog Rotary Cutter BH26 which requires a minimum 45 PTO HP and weighs 1095 pounds. Am I cutting it too close? I don't want to damage or bog down the tractor, but I have hills with small cedars that get in my way, so I need something sturdy enough to handle them. Thanks.
   / Need help with rotary cutter choice #2
I wouldn't worry about it, I used a Land Pride RCR2672 weighing 1046 pounds with my L5030 and it's a lot lighter tractor than yours. I also use a Land Pride HR3584 box scraper on my L5740 weighing well over 1100 pounds and it handles it fine.
   / Need help with rotary cutter choice #3
...... Am I cutting it too close? I don't want to damage or bog down the tractor......
You're not cutting it too close - the power guidelines are only approximate and the 3 pt lift rating has some tolerance too. You'll be fine with that setup.
   / Need help with rotary cutter choice #4
Where are you getting that 1200# max lifting number???
Your 3PH will lift 3300 lbs @ 24" and your FEL will lift ~2400 lbs.
Heck, my little L3800 will lift more than 1200 on the 3PH
   / Need help with rotary cutter choice #5
I run a 6' medium duty cutter on a M5040 and have no problems. As pointed out, the 3pt lift is over 3000#. For the width of the 5040, a 6' cutter is a good match. If you don't have a FEL, you will need front weights probably.
I originally ran that same cutter on a M4700, slightly less pto hp but never had any problems.
When you get into heavy stuff, you'll want to run in first gear anyway and you'll have plenty of horsepower. Normally I run in third gear when mowing except for very thick grass and weeds.
The rule of thumb is a minimum of 5 hp per foot of cutter. You have 7.5 hp so you're doing fine.
   / Need help with rotary cutter choice #6
I have a Kubota L4600 which specs just a little weaker than your tractor. I have a Woods brush bull 72 that looks close to your rotary cutter, and I love mine almost a perfect match. Mine gets a little heavy if I need to keep the tail wheel up for some reason, but that doesn't happen very often.
2012 Ford F-250 Crew Cab Pickup Truck (A50323)
2012 Ford F-250...
197390 (A50459)
197390 (A50459)
Stage Line Trailer (A50322)
Stage Line Trailer...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A52128)
Michelin CARGOXBIB...
Gator XUV560S4 (A50324)
Gator XUV560S4...
2020 CATERPILLAR 279D3 SKID STEER (A51242)
2020 CATERPILLAR...
