need help with oil leak
   / need help with oil leak #1
John22
Hi
I've inherited a Ford 5610. F registration.
It has a few problems. I have little mechanical knowledge so i was hoping somebody here could give me some advice.
There is an oil leak when i turn on the engine. The location is by the right rear wheel. I've put 4 pictures of the probem up at this address.
http://rolph4.tripod.com/Ford_5610_pages/Page_1.htm
Hopefully that will show things more clearly.
If possible can people give me their opinions as to the problem, and how it should be repaired and how difficult/expensive that might be.
Just for some background. Apparently it hasn't run properly for a few years. It has this habit of speeding up and slowing down as it sees fit. As if it gets little bursts of power (a few seconds) which it then loses. But in the last week the problem has deteriorated because now even at full throttle it wont go above 11 - 14 miles per hour.
John
By the way i've also got a leak on a Massey Ferguson 590. I've also got photographs of this here:
http://rolph4.tripod.com/Ford_5610_pages/MF_Page_1.htm
These pictures aren't as clear, so i'll just clarify the position is just beneath the gears and slightly forward. The oil drips a small amount consistently regardless of whether the engine is on. If it looks like there's some gunk there as well as the oil that was just my attempt to seal the gap. Any comments or suggestions welcome.
   / need help with oil leak #2
The 5610 looks like it can be fixed with a new "O" ring. It looks like you can remove that pipe by removing the bolt on the bracket to the right.
On the Massey, Is that a plate on the bottom or a cracked housing?
Plate, remove it and put in a new gasket. Crack, weld it or using JB Weld on it. Either way you will need to drain and the oil and clean the area real good.
2013 Chrysler 200 Sedan (A50324)
2013 Chrysler 200...
Pickup Truck Bed (A51691)
Pickup Truck Bed...
2002 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2002 Ford F-150...
2018 Lexus IS300 Sedan (A51694)
2018 Lexus IS300...
NEW 2025 Load Trail 83IN X 14IN Single Axle Utility Trailer (A52748)
NEW 2025 Load...
