Need Help with oil change on Montana 3644 HST
   / Need Help with oil change on Montana 3644 HST #1
FarmChick
Montana 3644 HST
I am about to burn the manual to this tractor because it is useless. Is there anyone that has a better diagram or pictures to show where the oil filter and drain plug is so that I can change the oil? I can't even find the dipstick that this manual shows to check the oil level. My husband and neighbor can't even figure this out. Thank you for any help.
   / Need Help with oil change on Montana 3644 HST #2
I assume this has the S4L2 Mitsubishi engine; I have the Mitsubishi engine operators and service manuals. Send me a PM with an email address where I can send you large files.
BTW, I assume you are changing the engine oil. If you are doing the hydraulic system then the Mitsu manuals will not help. If you are changing hydraulic fluid, the dipstick is probably at the rear of the tractor just above the axle. Mine is white. The hyd filter is huge and easy to spot under the tractor.
Oh thank you so much. I'm PMing you now. :thumbsup:
Mini Skid Steer Sweeper Attachment (A51573)
Mini Skid Steer...
NEW Wolverine 72'' Skid Steer Ripper (A53002)
NEW Wolverine 72''...
NEW Wolverine Skid Steer Drive and Augers (A53002)
NEW Wolverine Skid...
Kubota Salt-Spreader (A52384)
Kubota...
GORBEL EASY ARM LIFTING ARM (A52472)
GORBEL EASY ARM...
2019 Bobcat T590 Compact Track Loader Skid Steer (A51691)
2019 Bobcat T590...
