Need help with my Compact John Deere 2210
   / Need help with my Compact John Deere 2210 #1
HarrCo8224
Jewett
John Deere 2210
My 2210 has rear end problems. Dealer said it needs a new hydro unit, which I guessing is the whole back end because going to cost over $5,000 to fix. It goes backwards just fine, but struggles going forward. Doesn't bog motor down, acts like its slipping. Any ideas or suggestions on what to look at or may a place in Ohio I could find a tractor junk yard to find a used rear end. Just don't want to spend $5,000 to fix. Thanks!
   / Need help with my Compact John Deere 2210 #2
Just maybe a long shot here, but have you changed the oil and filter (also cleaned the screen) on the unit? Bought my 2305 new changed the hydro oil at 50 hrs. Screen had a lot of trash on it!
Yep, 😕, changed filter, hydro fluid, and cleaned internal screen. Still no change.
1994 Toyota 6000lbs 2 Stage Forklift (A51039)
1994 Toyota...
TMA (A49461)
TMA (A49461)
2018 INTERNATIONAL LT625 SLEEPER (A51219)
2018 INTERNATIONAL...
2012 PETERBILT 388 SLEEPER TRUCK (A51222)
2012 PETERBILT 388...
Morooka MST 660VD Tracked Dump Truck  Only 30 Hours (A51039)
Morooka MST 660VD...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
