Need help with JD 62C deck
   / Need help with JD 62C deck #1
moweraxle
Cortland County in Up State New York
Kubota BX2200
Need help! A customer has a J. D. X485 with 62C deck and wants a set of mower stands.
Can anyone measure with a pair of verniers the back anti-scalp wheel shaft (O.D.) And the I.D. of the tube that the shaft goes into.
Larry
   / Need help with JD 62C deck #2
moweraxle,
The shaft measures .895 dia. and it looks like the ID of the tube is .950. I say looks, because my veneer battery was dead, and I had to use an outside mic to eyeball the ID. Why is a stand needed? The wheels work pretty well for me. /forums/images/graemlins/tongue.gif
   / Need help with JD 62C deck #3
The back wheel shafts on my 62C deck measure .998/1.000 O.D. and the tubing measures 1.003/1.005 I.D. They are a pretty close fit. I tried to get a detail drawing on the JD web site, but it is not available for these parts.
Hope this helps. What did your customer give you for dimensions?
Ken /forums/images/graemlins/smile.gif
I make and sell a mower deck stand to stand your deck up vertically for storage and servicing. check out www dot moweraxle dot com
   / Need help with JD 62C deck #6
KEN,
Assuming my vision hasn't completely gone wrong /forums/images/graemlins/blush.gif (a distinct possibility), or the mower deck you have is different than mine, my pin dia is definitely .895. (checked again tonight).
moweraxle,
Interesting idea. Website could use some pizzaz (constructive criticism only). I know it sure would beat the shims and chain I used to hold my deck up!
Ken, Thanks again for the measurments. Maybe there is a differance between the 2210, 62C deck and the X485, 62C deck??
   / Need help with JD 62C deck #8
JDFANATIC,
Are you sure you are measuring the round (O.D.) area of the pin? The pin has flats on it (where the crossed drilled holes are) so you do not want to measure in this area. If I measure in the flat area it does measure .895, but this is not the dimension that moweraxle is looking for.
MOWERAXLE,
To the best of my knowledge the 62C decks are the same for both tractors. My deck even came with tractor mounting instructions for both models. The mounting is a little different.
Take care,
   / Need help with JD 62C deck #9
Ken,
I'm measuring on the full dia. -- it's definitely .895 Can't imagine why there is so much difference? /forums/images/graemlins/frown.gif
OK ! Everybody is right on the shaft size. Went to my J D dealer and the parts man said there are 2 sizes. Serial # up to 4000 are 1 size and serial # 4001 & up are a different size. He didn't have a shaft in stock so we don't know what size goes with what serial #. If someone with the 1" shaft would look at there serial # we could figure this mess out.
Thanks for the help everyone
Larry
2000 FORD F450 SUPER DUTY SINGLE CAB FLATBED TRUCK (A51406)
2000 FORD F450...
AUCTION STARTS HERE @ 9AM (A51406)
AUCTION STARTS...
PORTABLE INDUCTION HEATER (A52472)
PORTABLE INDUCTION...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
KONE CRANES SMV-25-1200 HEAVY LIFT FORKLIFT (A52472)
KONE CRANES...
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2016 Ford F-150...
