Need help with front suitcase weights for Ford 7710
   / Need help with front suitcase weights for Ford 7710 #1
pharmvet
Platinum Member
North East TX
Ford 7710 II FWA, NH TB110 FWA w/ NH 46LB loader, JD 5303 2wd w/ loader
After looking high and low, I finally found a really nice front bracket and 7 Ford suitcase weights for my 7710 FWA. Im going to take them off the bracket and use a wire brush and some nice Ford blue paint before I put them on my tractor. Each wt. is held on the bracket with a bolt tightened from the bottom. How are these wts. held together. there is a square hole in each one. Is there a special bolt, or do you just use all-thread and nuts on each end? thanks
   / Need help with front suitcase weights for Ford 7710 #2
Not familiar with your particular weights, but the suitcase weights on the front of my John Deere 2155 just have basically a piece of allthread through them with locknuts on each end. I would imagine that yours would be the same. All it is for is holding them together, and this is definitely the cheapest alternative too.
2018 CATERPILLAR 313FL EXCAVATOR (A60429)
2018 CATERPILLAR...
2022 Kubota LX2610SUHSD Compact Utility Tractor (A55315)
2022 Kubota...
2016 Toro Groundsmaster 4500-D 4WD Commercial Rotary Mower (A59228)
2016 Toro...
2019 CHEVROLET SILVERADO 1500 CREW CAB TRUCK (A59823)
2019 CHEVROLET...
S/A Utility Trailer (A59231)
S/A Utility...
Massey Ferguson 4710 (A60462)
Massey Ferguson...
