Need help with finding specialty hardware.
   / Need help with finding specialty hardware. #1
Kernopelli
Veteran Member
Carterville, Illinois
Mitsubishi MTE2000D, Dig It 258 Mini Ex, Deere Z930A ZTR
A buddy is doing a restoration on an old John Deere wagon and is looking for some chain binders. As he described them, "Every old grain truck I ever saw had this setup that pulled the bed sides tight so they didn't flap around".
The binders are made out of thin round stock and kind of shaped like a cam. One end of the binder is secured on one length of chain and the binder passes through the link of another chain and the binder is folded back over itself and pulls the chains tight then the binder is secured with a ring. Same principle as a lever binder or mini binder but simpler.
Anyone know what these are called and where to get these simple binders/fasteners. They would be easy to fabricate but he is wanting to go the easier route if possible.
   / Need help with finding specialty hardware. #2
J.E. Shaffer Co.
Tulsa Okla
come-along
MIGET
J.E. Shaffer Co.
Tulsa Okla
come-along
MIGET
Thanks for the reply but not exactly what he is looking for. This is more like a heavy wire that is shaped like an exaggerated "L" ( that is a really bad explanation but about as good as I can remember what he is referring to) that is passed though a link and cammed over to tighten the chain. The longer end of the "L" is then held in place by a ring or link. Very simple/cheap design.
   / Need help with finding specialty hardware. #4
My brother in law used something like you a describing to hold up the fence at a gap where ther wasn,t a gate it was made out of a piece of wood.
   / Need help with finding specialty hardware. #5
I know where there may be one on a set of old grain sides. I'll stop and get a picture in a couple of days if I don't forget.
The chain that was used with that type binder was called double loop.
http://www.homedepot.com/webapp/wcs...ping-_-googleads&locStoreNum=3902&marketID=58
   / Need help with finding specialty hardware. #6
Found this in McMaster Carr. Not exactly what I think you are wanting. Just maybe close. Need to add the ring. I recall them as being smaller and lighter in weight and just heavy rod bent to the right shape.
   / Need help with finding specialty hardware. #7
Makes me crazy when you know what the thingy looks like and used em for years and cannot find one or describe it.
   / Need help with finding specialty hardware. #8
Without seeing it, it sounds like the tire chain tightener binder deals. tirechains.com maybe?
   / Need help with finding specialty hardware. #9
sorta looks like a smashed spiral but not quite
   / Need help with finding specialty hardware. #10
Showing my age here a bit :ashamed: but i know exactly what you're looking for, though i'm not sure of a supplier.
I'd suggest checking with dealers for grain boxes for farm trucks, they may have some of the old bed chains and tensioners laying around.
2018 Chevrolet Tahoe SUV (A48082)
2018 Chevrolet...
T/A Gooseneck Dump Trailer (A50860)
T/A Gooseneck Dump...
2013 Ford F-150 4x4 Ext. Cab Pickup Truck (A48081)
2013 Ford F-150...
2015 Nissan Rogue Select SUV (A48082)
2015 Nissan Rogue...
2019 Allmand Trailer Mounted Light Plant (A50860)
2019 Allmand...
Unused 2025 Spirit Mini Golf Cart (A48082)
Unused 2025 Spirit...
