Need help with decision on JD2305
   / Need help with decision on JD2305 #1
jvncnt
Central Ohio
I have been trying to figure out tractors since we bought land last year to build a house. The house is about three months from completion and the time is coming quickly when I will need to get the tractor to get the land in shape. The land was farmland and is adjacent to a golf course. I will use the tractor to clear the driveway of snow (300') and will (hopefully) establish a lawn, put in beds and generally make it into a yard, with the mowing that will eventually entail. Now here is the rub.
I have been looking at both the JD2305 and the BX2230. I have been leaning towards Kubota primarily on price and dealer, but I recently met a JD dealer who is nice and has a good reputation. I can get a JD2305 w/MMM and FEL for $12,900, and the Kubota is pricing at $12,000.
I am not looking for anyone to bash the Kubota, and I know this is the JD section of this site. Nonetheless, can anyone tell me anything that I should know about the JD that I may not be considering when comparing it to the BX that makes the higher $ worth it?
Any input is appreciated, and thanks in advance.
   / Need help with decision on JD2305 #2
jvncnt,
Welcome to the forum. Both tractors are fine machines. I bleed green, so, you can take that with a grain of salt, but the features on the Deere that I like over the Kubota are: two pedal hydrostatic vs. treadle pedal (I think it is more comfortable to use); SCV joystick mounted on tractor, rather than on loader, and in better reach; 3PH connections are easier to make with standard pins on the Deere; the discharge chute on Deere's blower rotates hydraulically with the joystick (another reason to have it on the tractor rather than on the loader) but as far as I know, on the Kubota it requires a manual cable. Strength of dealer is important, so don't discount that, but after that, ergonomics, to me, rule.
Happy hunting!
   / Need help with decision on JD2305 #3
To start with, the JD 2305 is the 2006 model, and I believe the BX2230 is last years model. I think Kubota released the BX2350 in 2006 to replace the BX2230. They are both excellent sub-compact tractors and I would make my final decision based on Dealer support, and the basic ergonomics of the tractor in relation to your comfort while using it. I was at this point about 4 months ago and I chose the 2305 because I didn't like the tredle pedal that Kubota uses. I was used to 2 pedals, one forward, one reverse that is on my LT180 Lawn Tractor. Second deciding factor was the wife. She seriously dislikes the Orange color that Kubota uses. I test drove each of them and I don't rate one as superior to the other.
   / Need help with decision on JD2305 #4
Kubota has come out with a new model BX 2350 to replace the Bx 2230. You should really compare the 2305 to this model as they are both the latest and greatest form each manufacturer.
Both are good units.
   / Need help with decision on JD2305 #5
The new Kubota BX 2350 has two seperate pedals now, although one is still in the front and one is still in the back.
Also, the scv valve is on the tractor now and it is a 4 way valve to work a blower or blade. And as far as I know the 3ph arms are standard category 1 pins. Both the Deere and Kubota have easier working quick detach loaders. The Kubota BX 24 has a standard backhoe with swivel seat. I took one for a drive a couple days ago and was really impressed with the ergonomics of the Kubota. This surprissed me as I never really liked the Ergonomics on their larger machines such as the Grand L etc.
   / Need help with decision on JD2305 #6
How much mowing? I haven't seen a 2305 in person yet but it's pretty much the same as my 2210 with the exeption of a stronger loader and a different engine. The thing is really tough and well thought out. I don't think I've read about the new cx200 loaders on the 2305 but I can get my 210 loader off in seconds. In two years I have had ZERO problems.
This place is such a great resource. Thanks for all of the responses.
I have driven the bx2230 and will be driving the JD2305 tomorrow. I don't know if it was the treadle pedal or me, but I was bit jerky on the 2230. Guess I will find that out soon. As to platform size, I am all of 5'7", so didn't have any feeling of the 2230 being too small (had room to spare!)
Thankfully my wife is leaving this up to me. Well, kind of. She did enjoy driving the 2230 and told the salesman "wow, this sounds like a big tractor." I quickly realized my mistake and ushered her off of the tractor so that I could take my rightful place.
The only reason I was comparing the BX2230 to the 2305 was cost. I am feeling the crunch of building the house and thought that it would be okay with me to get the older model. I actually looked for a 2210, but to no avail. It probably would be more fair to compare the two newest models, but the best price I got was on the 2230.
What does "the scv valve is on the tractor now and it is a 4 way valve to work a blower or blade" mean to me. Not being rude, just don't know what that is. If anyone could explain, it may be important to me, I just don't know.
As far as mowing, I anticipate mowing a little over 3.5 of the 4.5 acres, until we do more landscape work. Eventually will hopefully be mowing less and less, but that will take time.
Thanks again for all of the responses, and keep em coming if you have time!
   / Need help with decision on JD2305 #8
I was in the exact position considering the same 2 tractors. I chose the 2305. My decision was based on a year newer model, the size difference in the wheels (for rough ground ride) and fit and finish. As far as the dealer goes, in my case the orange dealer in my area is better and closer. I don't regret buying the 2305. I know most talk about the pedal arrangement, but the pedals on the 2305 seem backwards to me. I push the reverse pedal to go forward almost every time. I think forward should be right, reverse should be left. Just think about driving a car with the pedals switched /forums/images/graemlins/shocked.gif
   / Need help with decision on JD2305 #9
rvtech, you'll catch on. SCV valve? that something the K dealer told you about? On the Deere the scv valve is standard. Its basically a hydaulic joystick. I definitely like the deere pedals better than the Kubby pedals.
   / Need help with decision on JD2305 #10
aesanders,
Talk to anyone who has owned a BX, and you will find that attaching a 3PH attachment is a struggle; the pins are turned to the inside and are not user friendly.
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tactor (A50323)
2009 Peterbilt 384...
2022 FREIGHTLINER CASCADIA SLEEPER (A51222)
2022 FREIGHTLINER...
2018 ISUZU FTR 24FT BOX TRUCK (A51222)
2018 ISUZU FTR...
(3) VACUUM PUMP TANKS (A50854)
(3) VACUUM PUMP...
2004 CATERPILLAR 963C CRAWLER LOADER (A51242)
2004 CATERPILLAR...
197637 (A50459)
197637 (A50459)
