Need help with axle..please.
   / Need help with axle..please. #1
bobodu
Platinum Member
Whitley County,In.EIEIO
Farmnought.Gravely Model L,Gravely Model LI,1941 Clinton two wheeler
I think I have the problem solved with the violent sway on my trailer.The DPO/builder just welded some 1/2 inch pipe to the frame for the top of the spring shackle straps and ran 3/8 bolts through.This left a lot of side to side play.Fixed all that.Now I would like to redo the bushings on the spring itself and here is where I need your help. I have no idea what the axle came from so I don't know where to buy them.It is a drop style with king pin knuckles and swing style springs.The brake drum is not integral with the 5 lug nuts.Of course, maybe you can help me find the bushings.1 inch OD x 1/2 inch ID x 1 1/2 inch long.
I went out to get a picture and was wiping off a rim.Found a GM mark.So I guess I'm all set. /forums/images/graemlins/grin.gif
   / Need help with axle..please. #4
If you still have some trouble McMaster Carr sells hundreds of different bushings and the size you discribed is pretty commom, happy hunting in your search.
1985 Ford Ltl9000 Tender Truck (A52748)
1985 Ford Ltl9000...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
4K SAND SEPARATOR (A52472)
4K SAND SEPARATOR...
(1) HD 27ft x 24ft Full Garage Kit Metal Building Frame (A51573)
(1) HD 27ft x 24ft...
John Deere WG48A 48in Walk-Behind Mower (A51691)
John Deere WG48A...
2018 INTERNATIONAL 4300 26FT BOX TRUCK (A52576)
2018 INTERNATIONAL...
