Need help with a Ford 5000 (5200 Row Crop) Neutral Safety switch.
   / Need help with a Ford 5000 (5200 Row Crop) Neutral Safety switch. #1
daryng
Gallatin
Ford 5200
I'm finishing the rebuild of my Dad's 69 Ford 5200 tractor. It's been a long process but it's nearing completion. I purchased a new wiring harness to simplify the process, however I'm having trouble negotiating the neutral safety switch. This tractor never had one (or wasn't hooked up) so I'm curious to how I could bypass it. I've tried several ways but I still am not getting any power to the starter solenoid. I know the OSHA police will chime in here, but this tractor has never had the use of one. It was always a common practice to make sure it was in neutral before you started it anyway so....
Any help would be greatly appreciated.
thank you
   / Need help with a Ford 5000 (5200 Row Crop) Neutral Safety switch. #2
The switch is closed circuit when the tractor's range lever is in neutral so there is power to the starter solenoid. So just connect the wires that go to the switch.
I've tried that but I still get nothing. I'm beginning to think it may be in the wiring harness itself. I'll go through and check continuity tomorrow. thank you
INGERSOLL RAND 100KW GENERATOR (A50854)
INGERSOLL RAND...
Unused 2025 CFG MY50R Mini Excavator (A49461)
Unused 2025 CFG...
2014 TROXELL KILL/TRANSPORT TRAILER (A50854)
2014 TROXELL...
2012 Ram 1500 4x4 Crew Cab Pickup Truck (A49461)
2012 Ram 1500 4x4...
2018 INTERNATIONAL LT625 SLEEPER (A51219)
2018 INTERNATIONAL...
2003 - 1890/1910 Air Seeder and Air Cart (A51039)
2003 - 1890/1910...
