Need Help With 3 Point
   / Need Help With 3 Point #1
Bravenrace
This started when I had a problem with my Ford 3000 tractor where it couldn't lift much weight with the 3 point or the front loader. I tracked it down to something inside the center section, under the seat. So I took the lift cover and cylinder off and found that the return pipe was broken. While in there I re-sealed everything, replaced the filter, and adjusted the draft and position control linkages per my manual.
That solved that problem, but now when in position mode, the 3 point won't lower completely. On a level surface, my grader box stops about 3" short of touching the ground. It works fine in draft mode. I took the side cover off and can access the position control adjuster, and tried shortening the adjuster road by one turn and it had no effect at all. I don't know what else to do with it, but I'm an out of work engineer and use this machine to make a living now, so I need to fix it fast. I'm a good mechanic, but am not that knowledgeable about this part of the tractor. If you have specific knowledge of this, and have any suggestions that would prevent me from needing to remove the entire assembly again, I would sure appreciate hearing them! Thanks, Jim
Thanks. I already made the adjustments per the manual. After posting, I went back in and shortened the link further and further until it ran out of travel. Then with the engine running and the cover off, I lifted and lowered the three point. It went down, but still not far enough. I stuck my hand in there and manually pushed the link rearward, and it lowered like it should. It's like the rod isn't moving far enough back to move the valve enough to work. But yet when I do it manually it works. It's kind of looking to me like I'm going to have to pull it all apart again. ��
   / Need Help With 3 Point #4
The last time I had trouble getting my three point to lower all the way it turned out I had the stop set on the control set so it COULDN'T lower all the way. I relocated the stop and all was well. I'm not saying that's your problem but it's one more place to check.
Case CX160C Hydraulic Excavator (A51691)
Case CX160C...
UNUSED RAYTREE RMDM725-72" DRUM MULCHER (A51248)
UNUSED RAYTREE...
2003 Ford F-550 4x4 Terex Bucket Truck (A51692)
2003 Ford F-550...
(2) COLUMN PROTECTORS (A51248)
(2) COLUMN...
2015 Freightliner Bucket Truck (A52748)
2015 Freightliner...
Case 580B Backhoe   (A52384)
Case 580B Backhoe...
