Ok, I got the injector to seal off once more. Now the engine developes the occasional skip and if I don't increase the throttle quickly the engine will die and is really hard to restart.
I need to mention that my property is all pretty vertical, being mountain wilderness, so I am not sure if I have bad fuel or poor fuel delivery.I was in the process of scooping up some gravel to fill some soft spots in my steep driveway when the engine died.
I plan on draining the fuel tank and going with all fresh diesel since I am beginning to believe my original problem may have began with water in my fuel. I cannot verify that, but I think it may have caused the original problem since water would not compress and blew out the copper injector seal. Once I got the leak stopped the tractor ran great as usual as long as I was on level ground up near my homesite.
Anyone else ever encounter a similar problem?
Thanks,
Bill
UPDATE:
I was just down at the bottom of the drive (where the tractor is...) removing the battery for a re-charge, and I noticed the plastic filter bowl don't look right. It is usually pretty clear and I remembered the guy I got it from had cracked the glass bexel on the fuel cap that allows you to see the level indicator.He had attempted to silicone the pieces to seal it and guess what...there is condensate clinging to the underside of the glass!
Incidently I was getting whitish exhaust just before she conked out so I am figuring that is unburnt fuel. Should I remove the glow plugs and turn over engine to clear this gunk out now? Afterwards should I try to prime it or should it be allowed to start in its own time frame (the last time it took quite a while to get all the air out even after evacuating all the air all the way to the injectors), also I know ether is a NO NO.
I guess it is time to go get greasy,
Bill
