Need help with 2320 Electrical, anyone have a service manual?
   / Need help with 2320 Electrical, anyone have a service manual? #1
ORCM
OC, OREGON
JD 2038R
Having problems with my 2320 starting. It looks like my fuel shut off solenoid is not getting voltage, I know there is a relay that controls it but I don't know which one or where it is.
   / Need help with 2320 Electrical, anyone have a service manual? #2
there are relays and a control timer involved with the fuel pull in solenoid. as far as I can tell they are all located behind the lower dash panel.
the relays are:
K3 fuel pull in relay wires: yellow, green, white/black, & blue
K4 control relay wires: black/red, red, orange, & green
the control timer is:
A2 pull in timer wires: green, black/red, yellow, and a 2nd green
Fuse:
F2 wires: red & red(on mine, it is not in the little fuse panel behind the muffler)
If the F2 fuse is blown the tractor WILL crank but not fire
give me your E-mail and I will try to send the SD and test procedures.
the relays are:
Fuse:
Okay, thanks! Sent you an email, with my email address.
2020 VANGUARD CIMC 53FT REEFER TRAILER (A54607)
2020 VANGUARD CIMC...
Mobile toilet (A53424)
2011 TEM 50' FLARE STACK (A53843)
2011 TEM 50' FLARE...
2018 FREIGHTLINER CASCADIA SLEEPER (A54313)
2018 FREIGHTLINER...
2015 KENWORTH T270 SERVICE TRUCK (A51406)
2015 KENWORTH T270...
1267 (A50490)
1267 (A50490)
