Need help with 16hp cast iron Briggs&Stratton timing setup.
   / Need help with 16hp cast iron Briggs&Stratton timing setup. #1
90cummins
Veteran Member
Florida Ma.
Ford 1720 SSS 4x4 Turbo Charged
I have a cast iron Briggs&Stratton 16 hp model 325431-0135-03
I am rebuilding it with a new OEM +0.010 piston and rod for my log splitter.
I completely disassembled the engine to the bare block and removed the breaker points push rod and installed a magnetron ignition.
The Briggs manual does not give a specification or procedure to precisely check/set the timing based on piston position.
Does anyone know how many degrees btdc it should fire or a piston position??
Thank 90cummins
   / Need help with 16hp cast iron Briggs&Stratton timing setup. #2
Timing is set by the flywheel. There should be a key for flywheel. That's all that needs to be done. Good luck with the project.
1969 JOHNSON J25 GOOSENECK TRAILER (A51222)
1969 JOHNSON J25...
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
2014 Whisper Watt Generator (A49461)
2014 Whisper Watt...
2014 Ford F550 Crane Truck (A50323)
2014 Ford F550...
2022 Down2Earth 82in x 36ft Two-Car Hauler (A51039)
2022 Down2Earth...
1041 (A50459)
1041 (A50459)
