Need help wih a middle buster.
   / Need help wih a middle buster. #1
Pete Judd
Veteran Member
The Thin Gravy Ranch in The wet PNW
Yanmar 186d, JD 314
I just picked up a middle buster, from Dells, our version of TSC. It is a Countyline. I changed the top link to a 14 inch when shorted all the way, But even with that, can't get it to go the last couple of inches into the ground. It seem to level out a couple of inches short. Yes, the 3ph, still has room to go down. Can't seem to find a shorter top link any place on line. Any Ideas?
   / Need help wih a middle buster. #2
Geometry.
Small rice paddy tractors were never set up to run deep digging implements like a middle buster. As a result, the 3pt arms are too short to get the proper geometry to dig correctly.
The only way to get your desired results, since your top link is already as short as possible, is to extend the length of the lift arms. I have seen pin on extensions at either tsc or atwoods, can't remember exactly.
   / Need help wih a middle buster. #3
Just by adding the Pat's Easy Change will extend them 4 inches!
2017 Rogator RG1300B Dry Fertilizer Applicator (A52128)
2017 Rogator...
2008 GMC C7500 Altec LRV55 55ft Forestry Bucket Truck (A50323)
2008 GMC C7500...
Caterpillar D7G Bulldozer (A50514)
Caterpillar D7G...
Pallet Of Mini Excavator Attachments (A47384)
Pallet Of Mini...
2013 VOLVO VNM TANDEM AXLE DAY CAB (A52141)
2013 VOLVO VNM...
2019 MMDI 14ft T/A Utility Trailer w/ Fuel Tank (A48082)
2019 MMDI 14ft T/A...
