Need help w/Kubota L4610 rear remotes...Hep meh!!
   / Need help w/Kubota L4610 rear remotes...Hep meh!! #1
DaddyRabbit
NC
Kubota L-4610 HST
I have a Kubota L4610 that has one rear remote on it. Therein lies the problem. I now need another outlet but mine is not stackable so this means its new valve time. Where can I buy ,(afford ably hopefully) a 2 or 3 pair outlet that will fit my 4610? According to my dealer they're unavailable until April of 08. I had him order off a new Befco spreader for me and now I can't even use the hydraulics w/it :( Thanks
   / Need help w/Kubota L4610 rear remotes...Hep meh!! #2
Do you have the factory remote? I thought they were stackable? Are you certain they are not? It it the valves or the outlet blocks (or both) that are the problem?
   / Need help w/Kubota L4610 rear remotes...Hep meh!! #4
   / Need help w/Kubota L4610 rear remotes...Hep meh!! #5
I had a 3710 Kub and they are not stackable. You might consider a 2-3 bank hydraulic selenoid splitter at one of the rear outlets. Probably much cheaper than buying an entire new set of hydraulics.
I just hate being screwed! Never once in my life have I ever tried to cheap my way out of something, (only one valve in this case) that it didn't wind up costing me double later. Nowadays its buy the best and cry once for me. Any idea as to where one can be attained?
john_bud said:
Rabbit,
The pic is of the outlet block. Those are stackable. The valve is the part where the handle is, under the fender. That part on the "10" series is not stackable, nor cheap.
2020 Caterpillar 302.7D Mini Excavator (A51242)
2020 Caterpillar...
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
2015 MACK GU713 DAYCAB (A50854)
2015 MACK GU713...
2016 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A50323)
2016 Chevrolet...
2008 Ford F-350 4x4 Crew Cab Pickup Truck (A50323)
2008 Ford F-350...
Kawasaki Mule 3010 UTV (A49461)
Kawasaki Mule 3010...
