Need help selecting hydraulic fittings
   / Need help selecting hydraulic fittings #1
Knight
CT
Kubota L3400
I bought a side link cylinder from SC with Sae 8 ports
I need a 90 degree fitting into 1/4" Hydraulic hose.
   / Need help selecting hydraulic fittings #2
Knight,
What is your question? A quick look at DHH does not have SAE8 90* fitting with 1/4" hose. So then decide if you want a 90* hose fitting with a straight adapter or a 90* adaptor with a straight hose fitting. I would go with which ever comes out cheapest. Or go to a local guy and ask what he has to make the connections. His stock may determine which way you go. Also he might have a 90* hose fitting with and SAE8 end.
   / Need help selecting hydraulic fittings #3
I don't know if you're going to find a 1/4" hose end with a #8 SAE 90ï½°, so your simplest alternative is to use a female JIC hose end with a JIC x SAE adapter. The major question is whether you want to put the 90° on the hose end or the adapter.
Option 1: FJX-04-04 (1/4" straight JIC hose fitting) and 6801-04-08 (1/4" JIC x #8 SAE 90°).
Option 2: FJX90-04-04 (1/4" JIC 90° hose fitting) and 6400-04-08 (1/4" JIC x #8 SAE straight).
You can order them online at DiscountHydraulicHose.com or, if these are the only parts you need, you can save the shipping charges and pick them up at your local hydraulic hose shop.
Ken
   / Need help selecting hydraulic fittings #4
Option 3. Get a 90 degree -8 ORB X -6 JIC and get a -6 JIC female put on your -4 hydraulic hose.
I'm pretty sure DHH stocks these. If you have 100R2AT hose you can get a field attachable hose fitting from them too.
Andy
https://www.globenewswire.com/news-release/2025/05/08/3077245/0/en/Nerve-Calm-Complaints-Investigated-2025-User-Reviews-Tested-Verified.html
https://www.globene...
2025 SDLANCH SDLGC80 UNUSED Electric Golf Cart (A53117)
2025 SDLANCH...
2007 50FT 3 CAR HAULER TRAILER (A53426)
2007 50FT 3 CAR...
Deere 700K LGP (A50123)
Deere 700K LGP...
PAIR DIAMOND PLATE DBL AXLE FENDERS (A51247)
PAIR DIAMOND PLATE...
City of Buckhannon - Power Curber 5700 (A52384)
City of Buckhannon...
