Need help picking a zero turn
   / Need help picking a zero turn #1
gostovp
Hi, Newbie here...in the market for a new zero turn mower. Have just under 2 acres to mow. Right now takes over 2 hours w/ my POS Cub Cadet 1554.
Doing my fall closeout shopping, One of my local dealers has a Gravely ZT HD 52 for $4500 and a Toro Titan MX w/ the 54 inch deck for $5300.
I also found Dixie Chopper Silver Eagle 2750 at a dealer about 40 miles away for $7400.
I've also read great things about the Hustler FasTrack and Scag Freedom Z's....but I think they run close to $6K
The Gravely is a good deal, and I seem to find good feeback on it online...or should I wait a little bit and spend a little more for the Toro, the freedom z, the hustler or even the Dixie Chopper..
any feedback is greatly appreciated!
   / Need help picking a zero turn #2
If you want to minimize the chance you will ever have to buy a lawn mower again, well at least in your life time, then you may want to consider a high end commercial ZT like the Kubota ZD3xx series. If these are too big, they also offer the 200 series. Kubota offers both product lines either gasoline or diesel powered.
When it came time to make a decision about replacing our current lawn mower this is the route I took. It only hurt once (when I wrote the check) but the ZT will last well past my life time. I know this isn't the best option for everyone but with 0% financing along with the piece of mid KTAC insurance provides, makes this route temping.
   / Need help picking a zero turn #3
I got a Hustler superz and couldn't be happier. The new model is even more impressive (15mph) and they too are offfering 0%. An acre of lawn almost takes more time getting on and off the trailer than it does to cut.
   / Need help picking a zero turn #4
over the years I have had the Sears riding mowers then I went ot the Scag zero turn which was not bad except the manual deck raising system was hard on my bad back. I traded for a Kubota "ZD" zero turn and have never looked back. Mine is the ZD 1800 (no longer in the line) with a 54 in deck and I could not be happier. I like the front end lift system for ease of cleaning and blade changing as well as the great economy and power of the small diesel engine. Comfortable to use for extended periods. I have an acre to cut on a weekly basis and about once a month I share in cutting an additional 17 acres. Bottom line a great mower built to last and that is why inmy area so many yard companies use Kubotas.
   / Need help picking a zero turn #5
I have a Gravely HD with a 25 hp engine & a 60" deck. I have over 300 HARD hours on it and I can't complain. Since I purchased mine they have upgraded from bushings to sealed bearings for the front pivot wheels & have use a heavier metal for the belt covers on the deck. My brother liked it enough he recently purchased one with the upgrades for himself. My sister has a 34" home owners model and my mother has the home owners version with a 52" deck. They are very happy with theirs. A home owner's model would not have held up to the use I put mine to. I pull a wood splitter with a log lift attached and a 4' x 8' trailer that holds 1/2 cord of wood with it. I have tractor styled lugged tires. (I went straight from the mower dealer to the tire store wher they took the brand new turf tires in on trade.) I wouldn't be without them. They have allowed me to mow & pull trailers is weather conditions I would not have had a chance of without them. I receive great service from my dealer. I have used Grasshoppers, Skags, Ferris, Hustler, & Huskys, for the money I have no problem with recommending a Gravely HD series ZTR. :thumbsup:
   / Need help picking a zero turn #6
I have never used one. I haven't even sat in the seat on one, but one of my brothers has 2 of them. I don't know the model numbers but both of them are commercial grade. One is made by Kubota and the other is made by Husqvarna. He swears by both of them. :)
   / Need help picking a zero turn #7
gostovp,
What is your budget? If it is below $5k, then the Gravely ZT HD 52 is a very good mower. It is a heavy duty consumer model (not quite commercial duty). Also how many hours do you put on your mower and is it a standard lawn (no big bumps or wooded trails or very steep hills)? If it is 50 hours or less a year and a standard lawn, then all you need is the Gravely. The Gravely has a decent 10 gauge welded mowing deck with ZT-3100 transaxles and a Kawasaki engine. As long as you keep the oil changed and keep up with the maintenance intervals, that mower will last you for many years. I had a the same mower for a while before I moved to a Scag Tiger Cat. While I had this mower, it was very good! I only moved to the Scag because I cut more than 5 acres, I cut trails in the woods and I tend to be more tough on my mowers.
If for any reason your budget is above $9k or $10k, then I would look at a commercial duty mower which there are many good ones. Some to consider in this price range would be: Scag, ExMark, Kubota, John Deere, Ferris, Hustler, Bob Cat (turf), Gravely Commercial, Toro, Bad Boy (Pup Series and above) and etc.).
   / Need help picking a zero turn #8
in a word Grasshopper.
With only 2 acres to mow dont think you need an 50, or 60 inch deck
A ZTR with a 48 inch deck will work just fine. Reduce your mowing/trimming time and be enjoyable too.
I have 4.5 acres to mow I have a Woods 6215 61 " deck with a Kubota DT722 diesel. (Grasshopper made it for Woods)
   / Need help picking a zero turn #9
Just wanted to interate what Oliver said about the Gravely. Had these machines been around when I was last looking, I would most likely have one. However, at that time, there was a huge gap between full commercial and homeowner models.
I have a DC Silver Eagle 2700-60D and it is commercial quality. Not the large frame you see most of the time like an Exmark Lazer or Scag Turf Tiger, but certainly in the same category as the Scag Tiger Cub was back then. If your budget can afford it, I don't think you'd be disappointed with the DC, but it will be overkill.
Another machine that I think is worthy of checking out would be a Husqvarna MZ5225ZT. Very similar to the Gravely/Ariens in construction, components, and price.
HUSQVARNA MZ5225ZT - Zero turn mowers
Thanks so much for all the quick and informative responses. Here is some more info on my situation:
My lawn is relatively smooth, biggest hill is my mound system for the septic. For the most part the lawn is pretty smooth, not golf course fairway smooth, but not rough like pasture or field road.
Our mowing season is from May to mid Oct (depending on weather). My wife likes to mow every 4 to 5 days depending on how fast the lawn is growing...so lets say at the 'most', 40 mowings per year...and right now it takes about 2.5 hours to mow w/ the 'piece of crap' Cub 1554 lawn tractor, so I'm thinking the zero turn will cut it to 1.25 hours...therefore I'm looking at 50 hours of mowing per year on average. I'm not going to use this to mow any other property or do any 'commercial' side jobs or anything.
The wife likes to mow, but the mower has to be easy to drive and manuever, easy to mainting and she is insisting on a quality machine after all the problems we have w/ the Cub. I sold my 17 foot Lund fishing boat to finance this, so I do have the $$ to put toward a more expensive machine if I want, but I'm debating on whether buying 'true' commercial vs heavy duty homeowner is money well spent, as we have 3 kids and one will be driving in two years, and we are getting to point of needing a vehicle w/ 3 rows of seats to haul 3 teens and pre-teens, thier friends, and a black lab...
So you can see my dilemma :)
Utility Trailer (A52377)
Utility Trailer...
2015 FORD E350 16FT BOX TRUCK (A54607)
2015 FORD E350...
2019 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
2006 GAYLEAN  130BBL VACUUM TRAILER (A53843)
2006 GAYLEAN...
Echo SRM2620 Gas Trimmer (A52377)
Echo SRM2620 Gas...
NEW HOLLAND C362 SKID STEER (A52705)
NEW HOLLAND C362...
