Need help picking a tractor
   / Need help picking a tractor #1
Theridge
Hey all... I am looking for a tractor to maintain my 30 acre hunting/get away property in western Wisconsin, Mostly wooded, with trails to cut, a small food plot to maintain, lawn to mow and grassie fields to cut. A 300' gravel drive to maintain. The local municipality plows the snow but there is always piles and clean up. Lots of wood to be cut and hauled out of the woods. Want to have a finish cut on the lawn but rough cut is fine for the trails and fields. General other chores. The property is on a slope in most of the areas... maybe 10%. I saw a used 2001 Kubota bx1800 54 inch deck and 3 point hitch with 465 hours for $6800.00. Would this work well? Any other ideas?
Need Advice
   / Need help picking a tractor #2
Need Advice
I think that BX1800 would be way too small for your needs.
I suggest you look at a tractor about the size of a New Holland TC-30, Kubota B7800 or Deere 790. They'd be a good size for your tasks, as you've described them.
   / Need help picking a tractor #3
Need Advice
Nothing wrong with used tractors either...so look for them. With your acreage, even a used ag tractor might work, and be in your price range.
   / Need help picking a tractor #4
Way to small. I think you should be looking in the 30 - 40hp range based on your discription of tasks. Mike
   / Need help picking a tractor #5
as the others have stated the BX is way too small also the ground clearence on the BX is not that great as compared to the B model kubota or similar name brand tractors of the same size.
   / Need help picking a tractor #6
I agree the BX is too small but given the tasks you outline, unless you are later going to do some serious clearing of that 30 acres, you don't need more than a 20-30hp CUT. Keep your eyes out for a Kubota 7510, 7610, 7800 or equivalent from JD, NH, Massey, Kioti, Mahindra etc.
   / Need help picking a tractor #7
Get more hp than you think you will need. Bigger tractors cost less per hp than small tractors, and you can get more done quicker. You want to enjoy some free time on your property, so you don't want to spend too much time on the tractor.
   / Need help picking a tractor #8
You can never have too much horsepower. The 3x20 and 4x20 series tractors by JD are pretty hot machines... and really easy to learn on if it's your first tractor.
   / Need help picking a tractor #9
Normally on 30ac, I'd say 35-50 hp.. however.. In this case.. mid 20's and up would be ok, as you may want a nimble small 4wd with a 5' finish mower, and a 4' brush mower, and rear grader blade.. etc. If you utilize the land later.. you may need bigger.. perhaps a used utility or ag tractor for pennies on the dollar.. etc..
Soundguy
   / Need help picking a tractor #10
I have a BX 1800 and have 30 acres and do a lot more with it than you want a tractor for. Yes you may be able to do it easier with more tractor but the 1800 will do it and it is real easy on fuel.
2014 Gillig 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig 31+56...
2020 INTERNATIONAL MV607 26FT NON CDL BOX TRUCK (A51222)
2020 INTERNATIONAL...
2012 Golf-Lift Hydraulic Turf Equipment Lift (A49462)
2012 Golf-Lift...
2025 LandHonor UHA-16-3000G 2in Utility Hitch Adapter Skid Steer Attachment (A49462)
2025 LandHonor...
80in HD Tooth Bucket with Side Cutters (A52128)
80in HD Tooth...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50323)
2016 Big Tex 24ft...
