Need help on x748
   / Need help on x748 #1
usmcshepherd
I have been looking at a ton of posts between this site and others concerning the topic of an x700 series mower and a SCUT (2305/2320) I am beginning to lean towards the x700 series as I really only need to mow currently, but would like to have the option of some minor implement useage (tiller, johnny bucket etc). I found a good deal on a x720SE with a 7-iron deck for $9900, but its gas and everything I've been reading from everyone is to go diesel. Well now the dealer has a 2006 x748 that they've had sitting around (only 25 hours) and they are willing to sell it as new for $9700. So now that I've decided to hold off on the SCUT/CUT until we arrive at our farm, I need some help on this one. Would it be better to have the x720SE with the 7-iron deck or the older x748 with 4x4 and diesel? Your suggestions will be greatly appreciated.
USMCShepherd
   / Need help on x748 #2
I had a 445 (gas) with a 54" deck and then upgraded to a X595 (Diesel) with a 62" deck. I cut my fuel consumption by about 2/3 and only use about 1/3 of what I did with gas. If your mainly doing mowing, the X748 would be the way to go in my opinion. My X595 is a 2001 and I just turn over 1000 hrs with out a problem. Good luck.
Curt.
   / Need help on x748 #3
just a caution, since it sounds like your looking to resell this... there are few machines out there that depriciate as quickly as highend garden tractors do. Being that you can by a new diesel SubCut for $8500 its really hard to move used garden tractors for much over 5000.
   / Need help on x748 #4
Messicks is right. If it was mainly for mowing, invest in a good quality ZTR and get a tractor later to use as a tractor. You'll be way farther ahead and have good resale on both.
   / Need help on x748 #5
USMCShepherd
$7750 new 4x4 Diesel VS
used 4x2 JD x720se GAS $9900.
$5250 used 4x4 Diesel VS used JD
x748 4x4.$9700.
   / Need help on x748 #6
USMCShepherd
Why would you want to spend $9700 to $9900 on an older used less capable tractor when as Messicks stated you can upgrade to a brand new upper level tractor for $8500? :confused::confused:
   / Need help on x748 #7
USMCShepherd
Its a shame you are not closer to Messicks...he could sell you one of those JD X700 Series lawn tractors he can't get rid of for 5K. :) I do agree however I would much rather have a small loader on any brand SCUT than a Johnny Bucket on a garden tractor..
   / Need help on x748 #8
The x700 can be fitted with a little better than a johnny bucket, if not 4WS. To the question posted, I'd go for the X748. Yeah, these are garden tractors, which aren't the same as SCUTs. But sometimes the GT is a better fit. The OP has to decide what best fits his needs.
2017 Ford F-550 Bucket Truck - 4x4, Powerstroke Diesel, Versalift VST47, 52FT Reach (A52128)
2017 Ford F-550...
2025 JMR 36in Mini Skid Steer Bucket Attachment (A50322)
2025 JMR 36in Mini...
2007 STERLING TRUCK ASPHALT DISTRIBUTOR (A50854)
2007 STERLING...
Glenco Disk Chisel (A50515)
Glenco Disk Chisel...
2022 Case TR340B Skidloader (RIDE AND DRIVE) (A50774)
2022 Case TR340B...
2021 HAMM HD+9I VO DOUBLE DRUM ROLLER (A51242)
2021 HAMM HD+9I VO...
