Need help on JD 425 throttle linkage
   / Need help on JD 425 throttle linkage #1
Iamblessed
Wetumpka,AL
Kubota F2680 mower, 1998 John Deere 425, 2006 Cub Cadet 2542 Garden Tractor
I had my engine out for several weeks to get it rebuilt and I can not figure out the placement of one of the springs.
I have looked at length at the service manual and at the parts diagram. They show a spring connecting to the end of the governor arm, I think it connects same place as the rod linking the governor and the throttle shaft on governor but I can not figure where it connects to carburetor? I have found a good source for rebuilding the Kawasaki FD620 engine. I don't want to put it on here as I don't have his permission but I will give information to anyone that will message me. I considered trying to rebuild mine but there is no machine shop in my area that will work on these engines as far as boring etc.
   / Need help on JD 425 throttle linkage #2
Attach a picture of the area you want help with, and I'll see if I can match that same area with a pic of my 425 linkage.
Fair enuf?
I am still in the stone age and don't have a good camera and my phone is no help. There is one small wire linkage between the governor arm and the carburetor throttle shaft. this is at the back of carburetor the upper link is for choke and the lower one is throttle. I am running it without this spring and it seems to work okay.
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
RYOBI 3300 PSI GAS PRESSURE WASHER (A51248)
RYOBI 3300 PSI GAS...
2014 Dodge Ram 5500 Chevron Wrecker Tow Truck (A51692)
2014 Dodge Ram...
BOBCAT T595 LOT NUMBER 139 (A53084)
BOBCAT T595 LOT...
1993 Trail Boss Lowboy Trailer (A52384)
1993 Trail Boss...
