Need help on clutch for Ford 3415 (1995)
   / Need help on clutch for Ford 3415 (1995) #1
cscigu
Sparks, OK
Kubota l3130
My neighbor is working on this tractor, but cannot use a computer. So, he calls me for these things. Lost my login info, so I created a new profile.
He is re-building this tractor for someone, and has the clutch assembly all taken apart. He's ready to put it back together, but wants some info on torque settings.
As best I understand, this clutch has 3 plates. He calls them pressure plates. They are held together by 3 bolts and nuts. The bolts go thru the plates. He wants to know how much to torque these when replacing.
The tractor is a 95 Ford 3415. Model aX413A.
Many thanks.
If you've got a link to any good diagrams or such, that would be great also. I'm heading to google to check on that stuff now.
For anyone looking in on this, or the slight possibility some future internet traveler may land here:
We were never able to find any answer for this. Finally he (the neighbor) called a Ford/New Holland service center. The tech there said they are no specs for torque on these bolts. They just "tighten them down". He said if he were doing it, he'd probably go for about 35 lbs. Now that does match some answers I'd seen for people working on car clutches.
MAGNUM PRODUCTS. 35KW GENERATOR (A50854)
MAGNUM PRODUCTS...
2011 Liebherr L586 (A51039)
2011 Liebherr L586...
2010 HEIL TOKEN TRAILER (A50854)
2010 HEIL TOKEN...
2021 FORD F-150XL CREW CAB TRUCK (A51406)
2021 FORD F-150XL...
2020 J&M 1151-22T Classic Grain Storm Grain Cart (A50657)
2020 J&M 1151-22T...
2018 RoGator 1100C (A51039)
2018 RoGator 1100C...
