NEED HELP LOCATING GEARS
/ NEED HELP LOCATING GEARS #1
SPEARS
Chardon, Ohio
Ford, NH
Does anyone have any idea where we might locate a used New Holland 2110 Compact tractor engine, OR balancer Idler and Crank shaft drive gears?
Have searched multiple salvage yards and a number of other suppliers.
Have an engine that someone has worked on already where the balancer idler gear came loose and lodged itself between a piston rod and the bottom of a cylinder bore locking up the motor.
We HAVE located a balancer assembly but can not find the 2 gears needed.
The Crank gear is p\n sba165416231, the idler gear has an assembly number of sba165026050 (which also includes two bearings). We need only the gear from this assembly.
If anyone can give us a lead to these we would be very greatful.
Frank @ Spears
John Deere 4955 Tractor (A66285)
John Deere 4955...
Landhonor MPF-11-2000G Skid Steer Pallet Forks  (A62679)
Landhonor...
2001 GMC C7500 Fuel Truck (A62613)
2001 GMC C7500...
2018 DRAGON  130BBL VACUUM TRAILER (A65643)
2018 DRAGON...
2 Horse Trailer (A62613)
2 Horse Trailer...
Landhonor HPF-11-3000G, 48" Heavy Duty Forks (A62679)
Landhonor...
