need help locating bucket teeth
   / need help locating bucket teeth #1
greenerdreams
Bronze Member
Hello, I have a ditch witch mx15 mini ex. i cant get the parts i need from dealer and can only locate what i need from australia but nobody will currently ship to the us(even if they would it would take a very long time). I lost 2 of my 3 bucket teeth, they are stamped with 5kc3 which seems to be very common but only in australia. Does anyone know if there is a suitable alternative that will fit the same shank? I am very close to just ordering a whole set of new shank/teeth and renting a plasma cutter to just start over with a new more common setup. I know if i operate for very long without the teeth, i will ruin the shanks and will have to cut them off.
   / need help locating bucket teeth #2
The have the pins vertically. Are they roll pins or are they flex pins
There are a few different styles of vertical pin teeth here in the states. For ~$6 a tooth I'd be inclined to try one.
But on a machine the size you yours.....you would have to put hundreds of hours digging in rocky dirt to wear out a shank to the point off needing it cut off.
2015 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A53422)
2015 Chevrolet...
AUTO REWIND 12V HOSE REEL (A54757)
AUTO REWIND 12V...
2022 MACK GRANITE TANDEM AXLE DUMP TRUCK (A54607)
2022 MACK GRANITE...
2013 MACK GRANITE (A52472)
2013 MACK GRANITE...
4 Unused Montreal ST205/75R15 Trailer Tires (A53421)
4 Unused Montreal...
2000 CATERPILLAR 140H MOTOR GRADER (A51406)
2000 CATERPILLAR...
