jimmie03
my john deere 2030 hyd just stoped working, no power steering ,no pto ,no front end hyd, help
Have you done the obvious, checked fluids, checked filters and screens, etc.
Do you know if the pump is actually turning?
Hydraulics:
Type: closed
Capacity: 2.5 gal [9.5 L]
Pressure: 2250 psi [155.1 bar]
Pump flow: 13.5 gpm [51.1 lpm]
I agree with J_J. Has any maintenance been performed. No pto if hyd operated indicates little to no oil being pumped by trans pump. Also check frt hyd coupler as they can fail. Be sure frt hyd pump shaft is turning with engine.
