Need Help Installing B205 Dozer Blade
/ Need Help Installing B205 Dozer Blade #1
IL4now
Mokena, IL
Kubota B7100HST
I just purchased a B205 4-way hydraulic dozer blade for my B7100HST. I have come across an issue getting this hooked up to the tractors hydraulics.
The blade was mounted to an older B7100 and used the high pressure from the diverter valve under the seat directly into the priority control valve. The low pressure overflow fluid then went to the tank
My newer B7100HST does not have the valve under the seat, but uses the hydraulic block near the HST pedal. I believe with the hydraulic block I need a control valve with power beyond as pressure needs to continue to the 3PH.
Can I put a (T) inline with the hydraulic block and have pressure to the priority control valve I already have? Or do I need to install a new control valve with power beyond?? If a new control valve is needed, can anyone recommend one for the B7100HST???
2026 SDLANCH SDLC2020 High-End Carport (A64194)
2026 SDLANCH...
2016 Dodge Charger Sedan (A64557)
2016 Dodge Charger...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
2016 Ford F-450 Ambulance (A64556)
2016 Ford F-450...
2017 GENIE S-40 TELESCOPIC BOOM LIFT (A65053)
2017 GENIE S-40...
2020 BOBCAT E35i EXCAVATOR (A65053)
2020 BOBCAT E35i...
