Need help hydraulics?
   / Need help hydraulics? #1
TomIre
College Grove, TN
Branson 3725
Was Bush hogging today and everything was normal. Raised the three point and it won't go back down. The linkage looks intact. The loader arms and transmission (HST) operate as normal. I did see that the hydraulic sight glass looks empty. No leaks seen but definitely empty.
I'll get more fluid tomorrow and fill it up until the sight glass is halfway again, but . . .
Any ideas what might be going on? Surprised it is staying up instead of dropping and surprised everything else working fine.
   / Need help hydraulics? #2
Could it be the knob under the seat? It controls the speed when going down but if it's fully closed, it won't let the 3 pt go down.
Sometimes when turning and looking backwards, you can hit it with your leg and eventually close it. Doesn't take much force at all.
Thank you my friend. You got it in one! Was actually my 13 year old nephew running it today. I'll beat him about the head and shoulders��!
And, the hydraulic fluid is right where it should be as well. Guess the nephew has more seat time tomorrow!
   / Need help hydraulics? #5
Nice! :thumbsup:
Don't worry. We ALL had that "3pt not dropping drama" happen one time or another. :D
   / Need help hydraulics? #8
If you install a hydraulic top or side link, you may have a "3 point not raising" drama too. Several times when the the linkage to my top link hydraulics sticks in one position or the other un-noticed (not neutral), the three point falls and won't go up. The first couple times this happened I was in a panic that my hydraulic system had failed.
   / Need help hydraulics? #9
I have the same problem on my 3510i - I still haven't fixed it.
My 3-point has been locked "UP" for quite some time now. The knob does nothing.
New/Unused 78in Quick Attach Grass Fork Grapple (A51573)
New/Unused 78in...
NEW 36'' Skid Steer Grapple Bucket (A53002)
NEW 36'' Skid...
WHYNTER ARC-102CS PORTABLE AIR CONDITIONER (A51248)
WHYNTER ARC-102CS...
UNUSED RAYTREE RMH680 HYD HAMMER (A51248)
UNUSED RAYTREE...
2023 John Deere 408R Sprayer (A53342)
2023 John Deere...
UNUSED RAYTREE RMBD72S-72" DRUM MULCHER (A51248)
UNUSED RAYTREE...
