Oil & Fuel Need Help-Hydraulic Fluid
   / Need Help-Hydraulic Fluid #1
lzicc
Platinum Member
Pittsburgh, Pa
Kubota B2650
One of my hydraulic lines got lose and I lost some fluid. I don't have any super udt left and the dealer is closed. What else could I use to top of the hydraulic fluid that would work? I have a tractor supply close to me if that helps. I probably only lost a quart, possibly a gallon.
   / Need Help-Hydraulic Fluid #2
You will need to know what kind of hydro oil you need, a universal or an AW type. If you cannot ID the correct oil, I would take a long coffee brake, wait till Monday and not risk screwing up your tractor. Take in a move and get out of the heat.
I just check the level glass and I am right at the bottom, so I think I should be safe to run it till I can get some UDT Monday.
   / Need Help-Hydraulic Fluid #4
Sounds good to me.
2011 Ford Transit Connect XLT Cargo Van (A50323)
2011 Ford Transit...
Wolverine Quick Attach Hydro Slide Pallet Forks (A50514)
Wolverine Quick...
2018 RoGator 1100C (A52128)
2018 RoGator 1100C...
2013 Honda CR-Z EX Hatchback (A50324)
2013 Honda CR-Z EX...
2024 KRUZ Ravens Tri Axle Dump Trailer (A47384)
2024 KRUZ Ravens...
Highway Products 8' Truck Bed Tool Box (A50515)
Highway Products...
