Need help getting a injector pump out of a Mitsubishi KE75 engine
   / Need help getting a injector pump out of a Mitsubishi KE75 engine #1
kenneth67
mitsubishi ke75
Hi
I have a KE75 mitibishi engine attached to my mulcher and need to get the injector pump out .I have done the 4 bolts undone an the injector pump lifts out 10mm I can seem to rotate it 180 deg but its court on something I,m guessing the control arm as I can feel it when I hold the control arm while trying to remove it.
People talk of removing a plate with 4 bolts to disconnect control arm from injector pump which makes sense but I don t have a plate with 4 bolt.
There is a plate with 4 bolt on the front of the oil pump housing which is close to injector pump housing I have removed this but there is just a bearing behind this.
So I,m at a lost the manual just states to disconnect injector out let pipes , remove 4 bolts and injector pump will just pull out .
Help pls I,m at a loss???
Ken
New Wolverine Skid Steer Forks Attachment (A53002)
New Wolverine Skid...
2008 CATERPILLAR 226B2 SKID STEER (A51246)
2008 CATERPILLAR...
2008 FORD RANGER SINGLE CAB TRUCK (A51406)
2008 FORD RANGER...
JOHN DEERE LOT NUMBER 138 (A53084)
JOHN DEERE LOT...
2011 DODGE RAM 2500 (A52472)
2011 DODGE RAM...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
