need help g174 tx100 need service manual or repair manual
   / need help g174 tx100 need service manual or repair manual #1
chicagosfo
bolens iseki g172 1517
hi.i just pickup iseki g174.tx1500e front loader..my clutch is stuck i can not engage gear ...any help.
   / need help g174 tx100 need service manual or repair manual #2
push or tow or drag tractor up to a large tree with the loader bucket
against the tree. With the tractor facing the tree and the bucket
against the tree put the tractor in 3rd gear. Push the clutch pedal
all the way in or all the way down, whatever you want to call it.
anyway with pedal in and transmission in 3rd, start the engine.
The clutch should become unstuck but be ready to
shut engine down if clutch does not come lose and tractor
tries to go up the tree. Use this advise at your own risk
I don't need someone trying to sue me if something goes wrong.
   / need help g174 tx100 need service manual or repair manual #3
A safer way is to run a pto implement with the clutch depressed. If that doesn't work you can run the tractor & hit he brakes evenly. Split the tractor if it won't brek loose.
Land Pride 3 pt 54" Box Blade (A50515)
Land Pride 3 pt...
2006 CHEVROLET SILVERADO 4X4 PICKUP TRUCK (A52141)
2006 CHEVROLET...
2003 Doyle Semi Horse Trailer (TITLE) (A50774)
2003 Doyle Semi...
2014 DIAMOND C TRAILER MFG. (A50322)
2014 DIAMOND C...
Kivel 3500 Lb Pallet Forks (A50121)
Kivel 3500 Lb...
TEST BID LOT (A50775)
