Need Help Deciding on Rental Hoe
   / Need Help Deciding on Rental Hoe #1
mcd176
Wheeling, WV
Kubota M6800HD / Kubota B2150
Hello All,
Ok, I am going to be renting a backhoe or mini excavator in a few weeks to do the following:
1. dig two culverts across my gravel road around 50' each 24" deep
2. dig out footers for a retaining wall about 40' long
3. dig an extension to my leech field about 100'
I plan on renting the machine for the weekend
The local rental yard has the following machines:
1. John Deere 110 Backhoe
2. John Deere 310 Backhoe
3. John Deere 35c excavator
4. Kobelco 45 excavator
I used to run a Case 580 hoe at my old job but have never run a mini excavator, with all of this in mind what do you experts think I should rent?
   / Need Help Deciding on Rental Hoe #2
I'm a long way from being an expert. But I would rent the excavator. Much more maneuverable machine. Since you're not doing anything needing a whole of power, I'd get something in the 3 ton range. If you get it Friday afternoon/evening and they pick it up Monday and you're already pretty good running a hoe, then I'd say you might be able to get all that done in a weekend. Good luck.
Take pictures..
Wedge
   / Need Help Deciding on Rental Hoe #3
Since you have the FEL, you don't really need another one. The tracked excavators are so much more maneuverable.
   / Need Help Deciding on Rental Hoe #4
Track hoe hands down.
   / Need Help Deciding on Rental Hoe #5
Another vote here for the Mini-Ex.
   / Need Help Deciding on Rental Hoe #6
Are you going to be driving across a lawn you want to keep? If yes the track type mini excavators are very hard to turn with out tearing up the lawn.
Mini excavator is nicer since you swing full 360 degress Vs 180 degrees with conventional BH.
Most mini excavators also swing the boom so that you can dig next to a building easier. Not sure if this would be helpful in digging the retaining wall footings or not.
Roy
   / Need Help Deciding on Rental Hoe #7
The only advantage of the backhoe would be if you need it to move materials some distance. Just for digging, I'd go with the mini excavator.
I have both a small Kubota backhoe (B21) and a mini ex (Kubota KX-121). The mini ex is a much more capable machine.
Ken
   / Need Help Deciding on Rental Hoe #8
Definitely the excavator. The 360コ rotation, plus the feature of the swing like on a R T hoe is great!! No picking of the outriggers, and lifting of the bucket to move. Just either turn 180コ, to look and keep yourself on track, or look over your shoulder, and hit the pedal to back up.
Not sure how much drop off you have at the end of your culverts, but it sure it sweet to leave yourself enough room at the end to turn out, come back around, and set yourself across, centered on the trench to finish.
Plus the fact of not having to look "around" the boom to see what you are doing. It's tough going back to a RT hoe, after operating an excavator, LOL..
   / Need Help Deciding on Rental Hoe #9
I also would lean towards 310 backhoe,mostly in case you need to move dirt etc. distance,plus if you get your project done early you might to decide on project which backhoe best for.
   / Need Help Deciding on Rental Hoe #10
Anything on your list will do this work in less than four hours time. Which one do you want to play with? I would go with the 35c excavator if it were me. I can tell you that is an easy quick job for the 110tlb and a 310 is overkill.
Which one is the cheapest to rent? That would be a good point too.
2016 Ford F-450 Crew Cab Knapheide Service Truck (A52377)
2016 Ford F-450...
1979 Chevrolet Step Van (A52377)
1979 Chevrolet...
PENDING SELLER CONFIRMATIONS (A54607)
PENDING SELLER...
2021 HAMM HD+9I VO DOUBLE DRUM ROLLER (A51246)
2021 HAMM HD+9I VO...
2008 Ford F-350 (A53422)
2008 Ford F-350...
