memphismark
Bronze Member
Hey guys'. I need help choosing a hydraulic pump for an auger drive that I use to spin a 2 yard concrete mixer I fabricated at the shop. I have a 22 HP motor that I'll use, and the auger drive is an Omni unit rated @ 8-12 GPM. I've been purchasing everything from Surplus Center so far. Using a Prince 20 GPM spool with a Prince cushion valve (rated @ 1500-3000 PSI) between spool and auger 'cause I had some problems with popped hoses due to deadheading. Surplus has a calculator saying approx. 1.6 cubic inch pump would work. Any suggestions. I'm a total novice and experience from people on the forum would give me some much needed 'piece of mind'. Used the auxiliary hydros on my Bobcat 753 up to this point, but I need to free up the Bobcat and not have it tethered to the mixer. Need lots of torque. thanks much. memphismark
