Need help! bobcat 963 leaking hyd. in chain case
   / Need help! bobcat 963 leaking hyd. in chain case #1
BC963
Prairieville, LA.
Bobcat 963
I recently purchased a 963 bobcat, knowing it had hydraulic leaking in the chain case. The guy I bought it from said he replaced both drive motor shaft seals and it didn't fix the problem, the motors are strong and pull straight. It leaks about 1gph when at idle, not working and 2gph when working it doesn't seem to leak when the machine is off after it has lost pressure. He believes it to be an internal drive motor seal and the motors need to be rebuilt, it seems to me there would be a loss of power or something wrong with their operation - am I correct here? Is there somewhere else hyd. oil can get into the chain case?
I've checked one case drain filter by the hydrostatic controller - it was clean. Is there more than one on this machine?
Thanks for any help.
Kubota SVL 75-2 (A53317)
Kubota SVL 75-2...
2017 Autocar Xpeditor T/A EZ-Pack 40Yd Front Loader Garbage Truck (A56858)
2017 Autocar...
2007 Volvo VNL Truck Tractor (A55315)
2007 Volvo VNL...
17307 (A55853)
17307 (A55853)
2004 John Deere 310G 4x4 Loader Backhoe (A56857)
2004 John Deere...
(9) ROLLS OF 5' - 10 GAUGE CONCRETE WIRE (A54757)
(9) ROLLS OF 5' -...
