need help asv rc 100
   / need help asv rc 100 #1
olinstransport
ft pierce fl
asv rc 100
hi there I have an asv rc 100 and it has run perfect until the other day. here is my problem the other day I was pushing dirt and I backed up a dirt mound and the pull off ad the machine started losing fuel and shut off. so I went and replaced all fuel and air filters the machine ran good for 15min and started spitting and spurdering and shut off. machine cooled down for hour and ran good for 10 min this keeps happening is there any one out there can help thxs chris
   / need help asv rc 100 #2
Welcome to TBN.....................
It could have air in the fuel line that needs to be bled out of the system. Don't know the age or hours on the machine but could also be the pump. Owners manual should explain how to bleed the air out.
Injectors could have some dirt or contamination or even a possible blockage in the fuel tank port where the hose comes out. If you have a see through filter you can watch it as it runs for 10 minutes. If the fuel level starts to drop the problem is in the tank. Another thing could be the fuel tank cap vent hole is plugged which will create a small vacuum in the tank as fuel is used preventing fuel from flowing freely.
Just some ideas.
thanks George I will investigate these ideas on
2013 Chevrolet Silverado 1500 4x4 Ext. Cab Pickup Truck (A52377)
2013 Chevrolet...
1999 FORD F550 BOX TRUCK (A54313)
1999 FORD F550 BOX...
2015 JOHN DEERE 624K WHEEL LOADER (A51406)
2015 JOHN DEERE...
THOMPSON F4L 1011 PORTABLE DIESEL PUMP (A51406)
THOMPSON F4L 1011...
CAT CS563 (A47477)
CAT CS563 (A47477)
2019 TEREX PHOENIX 2100 TROMMEL SCREEN (A54607)
2019 TEREX PHOENIX...
