Need Gate Entrance Examples
   / Need Gate Entrance Examples #1
hunterridgefarm
Veteran Member
Western NC
Kubota L3130DT, Kubota L185DT, JD LX277
This is a two part post.
So I'll start with part 1:) .
Our house should be complete in the next 2 weeks. At this time I have two tube gates at the entrance of our drive a 12' and 10' that I chain in the middle. It was a temporary gate as it started out as a 12' and I had to widen it inorder to get the roof trusses in. So I only have one post on each side.
My wife wants to have a gate when we get moved in. We are 400'-600' off the road and the house cannot be seen from the road. So I need examples of entrance gates. I have done a search and found a few. But it would be nice to look at some in the same thread.
So if you have an entrance gate could you post a picture here. I will try to keep the gate simple and will most likely use the tube gates in the beginning since I have several other projects I need to complete first.
Our drive will be graded next week so I will try and get a picture this weekend to show where the gate will be located.
Part 2:
We have discussed the entrance gate and to me it has pros and cons. The pro being we can lock it when we leave for the day or overnight. If someone wants in they can get in but the gate may offer some resistance or at least slow them down. They would have to cut my chain before they drove up and loaded my stuff:D .
The Con being if the gate is locked people will know we are not home!! What is your opinion on this especially if you have an entrance gate?
David
   / Need Gate Entrance Examples #2
I can't help you directly David as I still have the tube gate I put up before we began building. I can suggest though, that you have a look at all the posts from wroughtnharv. He's a master at gate and fence building. Who knows, maybe if you offer to host a TBN gathering at your new home, he'd show up and lead the crew in building for you!
Regarding the gate itself, I see it more of a statement of privacy. As you alluded, it won't actually keep the bad guys out but will keep the honest people from using your drive as a tourist destination. I don't think I've closed our gate since we moved in, but I still like having it there for the psychological barrier.
   / Need Gate Entrance Examples #3
Maybe get an opener. they make a log for the pin so it cant be disabled.
Dave
Rob,
I have looked at some of wroughtnharvs and he is the master gate maker! I also liked Eddie Walkers gate that had siding attached to it, and TNHOBBYFARM's gate. I guess I need to save them to a file so I can look them over good. But at home I have dial-up and going from thread to thread takes a while:) .
And hopefully I won't double post this reply;) .
John Deere 333E (A47477)
John Deere 333E...
UNUSED 20PCS Industrial Polyester Lifting Straps (A53117)
UNUSED 20PCS...
(INOP) 2015 JOHN DEERETS 4X2 GATOR (A51406)
(INOP) 2015 JOHN...
UNUSED IRANCH 15" EXCAVATOR WOOD GRAPPLE (A54757)
UNUSED IRANCH 15"...
2017 Nissan NV200 Cargo Van (A55788)
2017 Nissan NV200...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54607)
2019 FREIGHTLINER...
