Buying Advice Need filter advice - TU1700
   / Need filter advice - TU1700 #1
wcpeabody
Bronze Member
earth
JD 770
Well, I bought the 1700 I mentioned in the other thread. Now that I have it I want to change the oil and some other fluids before I really use it. It has been sitting for a while.
I have been searching the forum and the web but I can not find out what oil filter I should use. Does anyone have a common oil filter number for the TU1700? If I am not mistaken it is the same as TU1900 TU2100 G214/2104 models.
Also, does anyone have a link for where I can buy a manual?
While I am asking what about the air filter. Does anyone have a link for the model number and maybe where I can buy one online?
Thanks in advance,
Bill
(just for people doing future searches)
Because I need to do this tonight I called EFC Equipment and they told me Baldwin B243 which I am pretty sure converts to
Mobile M1-209 / Napa 1516 / Baldwin B243
I still need the other filter numbers or sources if anyone has them.
Thanks,
Bill
Well, I got the Napa filter and it does not fit in the space allowed.
I found on another list that AC Delco RF1245 is the right one but that does not correspond to B243.
I will probably try the delco today
   / Need filter advice - TU1700 #4
Bill I have a TL2100. Fuel and oil were no problem getting but I was having trouble finding an air filter for it. Leonard Sheaffer who posts here regularly had one. If your not sure about the filter #s take the old one with you to your parts store. They should have no problem matching it. The hydraulic filter on mine is a permanent one that you wash out. Don't know whether yours would be also.
Not sure what manuals are available for your machine. Parts would be a good one to have. With tractors that have been sitting alot acouple things you should do right away are change the hydrualic oil or at least make sure its not milky( water will seep into the transmission over time especially if the shifter boot is cracked or broken. Also change the oil in your injector pump and make sure the front axle if its 4wd has fluid in it. I've seen manuals for your machine on a site called Yenibiz out of Belguim but they ain't cheap. Gerry
   / Need filter advice - TU1700 #5
I will check and verify when I get home today, but if my memory serves me well a NAPA Gold 1307 will fit. I will also get the fuel filter and air filter numbers for you. Len is great with these tractors and nice to work with also.
Eddie
2016 VOLVO VNL300 TANDEM AXLE DAY CAB (A52576)
2016 VOLVO VNL300...
New Wolverine72 In Skid Steer Brush Cutter (A53002)
New Wolverine72 In...
2007 Hino 268 Truck, VIN # 5PVNE8JVX72S50442 (A51572)
2007 Hino 268...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
2009 HINO 185 18FT BOX TRUCK (A52577)
2009 HINO 185 18FT...
