Need Electrical Parts for LT1045
   / Need Electrical Parts for LT1045 #1
easymow
Gainesville, GA
LT1046
Where's the best place to buy parts for the LT1045 lawn tractor? A mouse chewed through several wires and almost through the spark plug wire. I spliced in the small wires and protected the plug wire and it runs fine, but I need to replace all of them. Is there an on-line source? I haven't found these parts in any of the "box stores" and hate to pay repair shop prices. Thanks!
   / Need Electrical Parts for LT1045 #2
I've gotten numerous parts from CubCadet.com. They sometimes have good prices, sometimes not, so I usually check the spendier pieces on one of the many ebay sellers.
- Jay
   / Need Electrical Parts for LT1045 #4
easymow - as an aside, didja chk under the engine's sheet metal cooling cowling for mice nests and related trash? If they are there, will prolly cause engine overheating/damage...
Thanks for the suggestion. Yes, I not only checked everything over thoroughly, but washed it all down with high pressure to clean out any small particles in the fins.
I really need a part number for the starter wiring harness, coil connections, and the plug wire. The owner's manual and the repair manual do not give us a part number breakdown.
   / Need Electrical Parts for LT1045 #7
You might start here.....LT1046 Tractor 2008 & after 13AP11CH010 | Messick's
The wiring harness is not pictured, but part number is listed. Make sure you are looking at the correct page for, your model year, and serial number range.
I am sure a phone call would remove any doubt, as to whether the harness listed, is the one you need.
Hope you get it fixed.
   / Need Electrical Parts for LT1045 #8
Ouch. hi press washer not too good on engine or rest of tractor. Better some delicate scraping along with compressed air or leaf blower. L&G powered eqpt just won't stand up to garden hoses and pressure washers. Electrical systems, and other fluid systems are not waterproof as compared to automotive. . Strongly suggest you change out your engine oil.
Thanks, Hill Billy Bob. I followed up on that and have parts on order. I'm comfortable they'll be the right ones.
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A52748)
2-Row Peanut...
1.5 Rolls of Red Brand Barb Wire (A50515)
1.5 Rolls of Red...
2013 Isuzu NPR-HD 16FT Reefer Box Truck (A50323)
2013 Isuzu NPR-HD...
2017 Ford F-550 4x4 Enclosed Utility/Air Compressor Truck, VIN # 1FDUF5HT6HED32921 (A51572)
2017 Ford F-550...
4K SAND SEPARATOR (A52472)
4K SAND SEPARATOR...
Case CX210D Excavator (A50514)
Case CX210D...
