Need Detailed Schematic of Branson 4220i rear lift cylinder
   / Need Detailed Schematic of Branson 4220i rear lift cylinder #1
tjc1989
East Texas
2006 Branson 4220i with FEL
The manual that came with my 2005 Branson 4220i tractor does not have much of a picture of the 3 point lift hydraulic piston, seals, and cylinder for disassembly and repair procedures. Does anybody have a better one they can share?
   / Need Detailed Schematic of Branson 4220i rear lift cylinder #2
Hello tjc1989,
how did you make out with this repair? I am getting ready to tear into my 4220 and had the same thought you did. the manual I have is basically tearing the 3pt apart including the arms and nothing specifically pertaining to just repairing the seal of the lift cylinder.
either way i'm gonna open it up just figured I would reach out to see how you made out. or if you have anything to watch out for??
thanks in advance
   / Need Detailed Schematic of Branson 4220i rear lift cylinder #3
TJC try this link this should be the complete part breakdowns for your model tractor
422.pdf - Google Drive - sorry the first attachmetn was wrong this should be the correct one.
2004 Dodge Ram 1500 4x4 SLT Crew Cab Pickup Truck (A50323)
2004 Dodge Ram...
(10) 2 PLUG VALVES (A52472)
(10) 2 PLUG VALVES...
Electric Wheel Hyd. Dump Wagon (A50515)
Electric Wheel...
10x16.5 Tire Assembly (A52748)
10x16.5 Tire...
2007 MACK CT713 ROLL OFF TRUCK (A52141)
2007 MACK CT713...
2013 Chevy Silverado 2500 HD (A52748)
2013 Chevy...
