texascowman
- Joined
- Feb 6, 2011
- Messages
- 3
- Tractor
- John Deere 750 dozer
Pushes and steers fine at 3/4 throttle but not at full throttle. Filters are new. Any suggestions or knowledge much appreciated.
If your issue is linear, that is the same amount of loss throughout the throttle range, it might be that the right motor is slightly off stroke and may just require control adjustment (you will need a manual for the specs). If the loss is logarithmic, that is the loss becomes greater with throttle increase, it could be time for a motor rebuild. Too bad the service meter isn't working, they are kinda important. Simple thing to check first is the pump couplings.Haven't had it all that long. Unk if anything has ever been rebuilt. I recall the left side being a little stronger when we first got it. Hour meter is broken.
any one no what could be wrong with a 750 b long track the moter starts fine but nothing else works herd it could be a main shaft that comes out of the moter and goes in the gear box any awnsers ?
