Gordon Gould
Super Member
- Joined
- Apr 1, 2007
- Messages
- 6,569
- Location
- NorthEastern, VT
- Tractor
- Kubota L3010DT, Kubota M5640SUD, Dresser TD7G Dozer
I need to replace 3 steel 3/8" ID hydraulic lines on my dozer. ( A slow leak turned into a big leak ). I have never worked with steel lines. I know they are not available as spare parts. Will I need to replace these with rubber lines or can steel lines be made up at a reasonable cost ? Who does this ? If I go rubber it will be a little tight at the female end. The 3 lines are about 3 feet long.
The steel lines were clamped with a bar just above where they connect to the rubber lines to the blade cylinders. There is no flex in the lines they are stationary. If I go rubber what would be a good way to clamp them. I could fab a bulked with three male to male bulked fittings through it but that seems like a lot of work and I am hoping there is a simpler clamp that would be satisfactory. Looking for suggestions.
Here is two pics of the leaky male ends that were clamped and one pic of the female ends. The thrid line is the one underneath.
Thanks for the help.
