need advise on ford 1200 front differential
   / need advise on ford 1200 front differential #1
Kenfranklinl
massachusetts
ford 1200
Hi all, I took my front differential apart and found a broken tooth on the pinion gear but the ring gear looks OK. Can I change out the pinion gear and use the same ring gear or does it have to be a matching set? where is the best place to get these parts?
Also the spider gear shaft which I know is a floating pin looks like one end hit something. can in move that far to hit the differential casing?
Any help would be appreciated.
Ken
   / need advise on ford 1200 front differential #2
Usually you put a matched set in order that the wear is the same, unless you just want to get it working or don't care etc. It really depends on the wear on those gears.
2006 JLG 460SJ Man Lift (A51573)
2006 JLG 460SJ Man...
2014 TEXAS PRIDE GOOSENECK (A52472)
2014 TEXAS PRIDE...
JOHN DEERE 5125R (A53084)
JOHN DEERE 5125R...
2016 TANKKO 130BBL VAC TRAILER (A52472)
2016 TANKKO 130BBL...
3-Point Hitch Root Grubber - Heavy-Duty Tree and Stump Puller for Tractors (A52748)
3-Point Hitch Root...
