Tiller need advise on 2 pt tiller hook up
   / need advise on 2 pt tiller hook up #1
mikeq
medina tn
massey ferguson/huskvarna
I have a massey ferguson 135 i am hooking up a rototiller to.my problem is when i am tilling it shifts to the left and causes the pto shaft to bind.my lift arm swing side to side when it is in up position.i do have chains on lift arms to keep them from going to far.but i feel i need something else to hold the lift arms more centerde and allow less swing side to side .any ideas?
   / need advise on 2 pt tiller hook up #2
Your chains should be able to limit movement down to nothing.
Take out a link on each side maybe? Or do you have that option?
Sometimes you can cheat by using a repair link to shorten the chain, if the turn buckle can't take up all the slack.
Pics would help..as always.
The Massey 135 is one of my favorites anyway.:D
   / need advise on 2 pt tiller hook up #3
Get a set of stabilizer arms like these: Tractor Supply Online Store - Enjoy searching:stabilizer arms
If your tractor doesn't have the brackets to attach them to, you'll need a set of those too.
These are just an example, most small equpment jockey's that deal in used equipment, but also handle new parts should have, or be able to get them. I entered my zip code, just to get pricing to give you an idea what they should cost.
   / need advise on 2 pt tiller hook up #4
MF 135s have a bracket under the axle attached by the bolts that hold the fender on. There should be several holes there to attach a stabilzer pin through (A stabilizer pin looks like a very short lift arm pin). That will be where the forward end of a stabilizer will connect. Use two stabilizers rather than one. This will help prevent bending the stabilizer. I prefer one solid stabilizer and one adjustable.
On the TSC page posted by DJ54 there is a photo of the bracket on the third row down second photo from the left.
2017 Buick Encore SUV (A50324)
2017 Buick Encore...
Heavy Duty Skid Steer Auger ECAG W/ 6", 12", and 14" Bits (A47384)
Heavy Duty Skid...
2022 Adams CLC-1013 Conveyor - New (A52128)
2022 Adams...
2015 Ford Expedition EL XLT SUV (A50324)
2015 Ford...
2021 GMC SIERRA CREW CAB TRUCK (A51406)
2021 GMC SIERRA...
KUBOTA M7060 TRACTOR (A51243)
KUBOTA M7060...
