Need advice
   / Need advice #1
Stlrver
Kubota m9540
I have a kubota m9540 now and need dual rears to be able to safely mow my steep levees. Mowing up and down is not an option. The kubota dealer says the 9540 can't handle the dual rear tire stress on the axle.
Does anyone have recommendations for a dual rear tractor in the 100-125hp range? I have deere, case and kubota dealers close by.
Are bolt on rear tires as good as ones on the axle?
   / Need advice #2
Have you discussed adding wheel spacers with the Kubota dealer?
Wheel spacers would give you 8" - 12" of total additional width, without the tire weight.
Has your Kubota a cab, which increases weight and raises the center-of-gravity?
   / Need advice
I have not asked about wheel spacers and yes it has a cab. Thanks for the reply.
   / Need advice #5
I agree with Egon, now. The cab on your Kubota probably weighs 850 pounds and that weight will be 3/4 riding on the rear axle.
   / Need advice #6
Without knowing the size and scope of your levee's, what about an offset flail mower, a boom mower, or a sickle bar mower on the back of your existing tractor?
   / Need advice
Levees are about 15ft high and most have water constantly at their base. I like idea of a sickle bar but how big do they get? I would need a really long one... 15ft at least. I don't think that exists. Thanks for the reply
   / Need advice #8
Levee pictures?
How long is the distance and grade? Just a 2x4 with level on it and a tape measure works (length-height).
I mow my steep grades with a Cub Cadet zero turn...very steep. It's very safe, quick, easy.
   / Need advice #9
How tall is the grass you have to cut? Is it like a lawn? Or a field?
   / Need advice #10
Wow, how much mowing are you doing to justify a 100+HP dual rear tractor?
Have you considered an excavator with a brush hog or flail? Sounds like a better option than getting a huge tractor stuck because one wheel went swimming at the bottom of a levee, but that’s just the picture of myself as the operator in my mind.
2019 Harley-Davidson FLHTP Police Electra Glide Motorcycle (A50324)
2019...
2020 Ford F-150 Crew Cab Pickup Truck (A50323)
2020 Ford F-150...
2012 Cat 272C Skidloader (RIDE AND DRIVE) (A50774)
2012 Cat 272C...
Pickup Truck Bed (A51691)
Pickup Truck Bed...
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2011 Ford F-150...
2013 Ford F-550 4x4 Altec AT40M 40ft Bucket Truck (A50323)
2013 Ford F-550...
