Need Advice "Stamped or Fabricated"?
   / Need Advice "Stamped or Fabricated"? #1
trum979
West Central Indiana
Kubota B 2620-RTV 500
I am thinking about buying a ZG222 ZTR. Would like some thoughts on whether to go with a stamped of fabricated deck. What are the advantages of disadvantages of each? Why is the fabricated $400 more? Better bearings,
heavier gauge, or what? Will it last longer? Is it worth the extra bucks? Would appreciate any and all feedback on this subject. Thanks.
   / Need Advice "Stamped or Fabricated"? #2
The fab deck is a heavier and stronger deck that will last longer. Also if you bump into something its not gona dent like the stamped deck will. It will also last long in a sandy lawn better than the stamped.
   / Need Advice "Stamped or Fabricated"? #3
Fab is way better than stamped.best way is for you to go and look at the two and you'll see right away that the fab. deck is built with heavier material,the spindles are better,belts are better etc. russ
From what I can determine, it has a kubota built gas engine. I also looked at the mid grade line of Gravely ZTRs which seem to be substantially built with kawasaki engines. I can get the kubota at 15% off list plus they have reinstated their 60 month 0 % financing on the ZG models. The kubota is about 30% more but I figure it will hold its resale much better.
   / Need Advice "Stamped or Fabricated"? #6
Get the fabricated deck, well worth the $400. I'd also consider upgrading to a diesel unit. More acres/gallon, less maintenance and it will outlast you. I'm very happy with my zd21, it's 5 or 6 years old with 400+ hours. You're going to love the zero turn, it makes mowing fun.
   / Need Advice "Stamped or Fabricated"? #7
If you cut for 30 - 40 hrs a year for , say 8 years , the resaleable price
at this age is too difficult to guess . As for diesel engines/price/fuel use :
not worth the $1700 extra , and on an old machine , nobody is
bothered with your engine , only what they can get for a few grand ......
DO GET the correct width deck first time !
   / Need Advice "Stamped or Fabricated"? #8
Stamped metal is metal that has been work hardened by the stamping process. It doesn't take much bouncing around on stamped metal before it starts getting stress fractures. I had an all stamped 72" RFM mower once. It started disintegrating at the end of the first season.
Thanks for the replies. Most of you just reafirmed what I had sctually been thinking thinking. However here is another thing I am curious about. Their speck sheet shows the ZG 227 as having 27 hp. How do they get 5 more hp out of an engine of the same displacement with the same rpm rating. Just curious!
   / Need Advice "Stamped or Fabricated"? #10
Different carb . Same as with cars . These are Kohler numbers : ask
if they are the base-model rubbish with non-metal valve train parts .
This engine range is one of the reasons the T series Kubota don't sell.
I'd look at Kawasaki engine equip IMHO . Hustler etc .
2014 John Deere 450J LGP Crawler Tractor Dozer (A42742)
2014 John Deere...
2015 FreightLiner Cascadia Daycab T/A Road Tractor (A42021)
2015 FreightLiner...
Kivel Quick Attach Hay Spear (A40786)
Kivel Quick Attach...
2014 KENWORTH T680 (A45046)
2014 KENWORTH T680...
7064 (A39855)
7064 (A39855)
John Deere Gator (A44391)
John Deere Gator...
