Need advice... Railroad mowing tractor!
   / Need advice... Railroad mowing tractor! #1
PapaPerk
Veteran Member
USA
Kubota L3830, Ford Golden Jubilee, 1939 Sears Economy, Polaris Ranger 400, Honda Foreman 450 ES, 2004 Dodge Diesel 3500
Howdy all. Have an usual question for you all... Looking for some opinions.
My friend is in search of a tractor to mow and maintain a railroad right of way! Budget is around $10K. The tractor would be used along the tracks to knock down brush, etc with a bushog. As you know railway right aways can be a little burly.
My initial thoughts is a 4wd with loader running a 6' bush hog. I was thinking of something the size of a Kubota M5040. Sure would be a good application for industrial tires.
What are your thoughts? An older Deere or Ford maybe an excellent choice.
Any advice much appreciated. Thanks!
   / Need advice... Railroad mowing tractor! #2
4WD, FEL, 6-ft hog, 50 hp tractor--for $10K? Look for used tractor like a 1980s vintage JD 2640 tractor (the "Field of Dreams" tractor). My neighbor has one with FEL but no 4WD that he bought for about $7K.
There are plenty of similar tractors in the 30-50 year old range that you might consider. But good luck in finding one with 4WD that fits your $10K budget.
My 1964 MF135 diesel (45 hp engine, 37 hp pto) would handle a 6-ft hog OK. But no 4WD, no FEL and standard gear shift tranny. Cost me $3600 with 4600 hours showing.
   / Need advice... Railroad mowing tractor! #3
How many miles does he have to mow and how often?
This is wooly work. I'd skip the FEL. Use that money to have a forestry cage built on it and add some skid plates and foam the tires.
Does the 10,000 include the cutter? If so he needs to bite the bullet and buy a heavy duty one and that will burn up near half of the 10 just in the cutter.
   / Need advice... Railroad mowing tractor! #4
How much railway right of way are they trying to maintain ?
How steep are the banks ?
   / Need advice... Railroad mowing tractor! #5
   / Need advice... Railroad mowing tractor! #6
First image that popped into my mind was a gigantic cutter bar suitable for going through locomotives.
   / Need advice... Railroad mowing tractor! #7
I've seen some mowers on a backhoe or boom. Something that could be angled as need be. I don't see the need for a FEL, but it you had a bachhoe that would already be there.
   / Need advice... Railroad mowing tractor! #9
he ain't gonna get what he needs for 10k
   / Need advice... Railroad mowing tractor! #10
I would not want that job
Honda EU3000is Gasoline Companion Inverter Generators (A54811)
Honda EU3000is...
CATERPILLAR 308E2 CR EXCAVATOR (A50458)
CATERPILLAR 308E2...
2000 Trail King TK70SA-48.2 T/A 43 Ton Hydraulic Slide Axle Step Deck Trailer (A52377)
2000 Trail King...
2010 Hyundai Elantra Touring Sedan (A51694)
2010 Hyundai...
2014 MultiQuip WhisperWatt 40kW Three-Phase Diesel Generator (A52377)
2014 MultiQuip...
2016 CATERPILLAR 336FL EXCAVATOR (A51246)
2016 CATERPILLAR...
